Clutch foot lever not function properly
  • Shane Briggs
    • Nov 2011
    • 76
    The clutch on my 1938 Chief will not stay disengaged. I cleaned up and scuffed up the friction washer, media blasted the surface of the friction plated and tighten the spring nut as far as it would go and it would not hold the pedal in the disengaged position when the motor is running. Any advice would be appreciated. Thanks
  • Shaky Jake
    Ol' Poop
    • Jan 2013
    • 261
    I had that problem with my ‘41. In my case it turned out that the pin that keeps the stationary friction plate stationary was sheered off. You’ve probably already checked that, but if not...
    Kevin
    Kevin
    • Shane Briggs
      • Nov 2011
      • 76
      [QUOTE=Shaky Jake;182478]I had that problem with my ‘41. In my case it turned out that the pin that keeps the stationary friction plate stationary was sheered off. You’ve probably already checked that, but if not...
      Kevin
      Yep, the pin is in good shape. Thanks
        • 962
        How hard is it to depress the pedal?
        IF the chutch disc stack is a little high the spring tension is higher and may be to much for the friction disc.
        • tomfiii
          • Jun 2007
          • 314
          Check with Mike at Kiwi to see if he has the correct tension spring and old style disc in stock.
          • Shane Briggs
            • Nov 2011
            • 76
            The pedal is not really hard to depress, but I have been wondering if the clutch springs might be the cause of the problem. Guess it makes sense to go there next. Thanks
