welded in 34 chief case baffles
  • cscott
    • Oct 2002
    • 451
    someone welded in these strips of aluminum to replace broken out baffles, what do you think? leave or remove? also does anyone recognize this ride control thanks chris
    • 8231
    Chris!
    It looks like a Crocker Chief dampener with a 'custom' knob.
    The case repair depends entirely upon the skills of the welder, and the machinist who then fitted the mains.
    If the cases did not distort, it was worth it.
    PS: Example shown was found in a barn floor with a garden 'claw'.
    It illustrates that the brass stem was fragile, broken off in the nut, probably explaining your odd knob.
    Frame bracket on right was by Michael Breeding.
    • Shaky Jake
      Ol' Poop
      • Jan 2013
      • 261
      Originally posted by cscott View Post
      [ATTACH=CONFIG]23672[/ATTACH][ATTACH=CONFIG]23673[/ATTACH][ATTACH=CONFIG]23674[/ATTACH]
      If you're using oil control rings on your pistons, you probably don't need baffles. If you don't know the history/quality of the work, I'd say taking them out would be the safe bet. That's my thought.
      Kevin
      Kevin
      • kitabel
        • Sep 2018
        • 471
        In an H-D engine, the baffle slot is only a bit larger than the widest path of the rod beam (plus extra side-play for wear). The purpose is to create vacuum under the rising piston to draw oil (collected by splash under the baffle) up into the cylinder. Bore area ÷ slot area = large number. Since the rear cylinder gets some from flywheel throw-off, later engines only have a front baffle.
        The Indian baffle slot is much wider. Bore area ÷ slot area = smaller number. Why?
        The Linkert Book
        • tomfiii
          • Jun 2007
          • 314
          Iwould leave them in if clearance ok,but take to competent welder to check out. The rocker shafts Need inspection closely.
            • 2018
            I'd leave them in.
              • 8231
              I dunno Kitabel!
              But here's my never-to-be-finished 334;
              The front rod slot is ~5/8" wide, the rear a fat 15/16", both for a ~3/8" wide rod.
              Note the holes in the front baffle.
              Some say it is to aspirate upward, however it is obvious that they would also be drains when the motor stopped.
              I chose not to repair, nor remove the broken baffles.
              Removal allows the cases to flex, and weld repairs usually distort enough to require re-decking.
              I'd inspect the cylinder decks first, Chris!
