New clutch won’t disengage (after sitting dry for 3 years)
  • larrymgibson
    • Aug 2015
    • 70
    1947 Indian Chief. My engine, transmission and clutch were rebuilt by a pro shop 3 years ago. I made sure the engine was lubricated and turned over regularly. I finally got it running and before riding I checked only to find the transmission and primary were dry. After filling, the clutch will not disengage. The lever moves too easily. I thought maybe the clutch discs were stuck after being dry for three years. If that is so, what would be a good way of unsticking them? (The rebuilder retired and closed his shop 2 years ago)
    Thanks for helping.
    Larry Gibson
    • 971
    I think the lever resistance would not change if the friction and steel plates were stuck together.You could try to bring it up to temp and then rock the bike back and forth with motor off ,but My recommendation would be pull the cover and see whats going on.
    • larrymgibson
      • Aug 2015
      • 70
      Here's a painful video of the attempt to get it in gear.
        • 971
        Work on getting it to roll in gear after warm up with the clutch in and in gear before you do any more grinding with motor running.
        • tomfiii
          • Jun 2007
          • 316
          Use high gear for rocking it back and forth.
          • larrymgibson
            • Aug 2015
            • 70
            Thanks. Will be doing that today. Should I drain the oil and replace it with something thinner (now has 30 weight non-detergent) or heat up the oil and refill the case?
              start it in gear while up on the rear stand. After sufficiently warmed up hold the clutch pedal down and have someone push you off the stand. Keep the clutch pedal down while you accelerate and back off.
              • larrymgibson
                • Aug 2015
                • 70
                Good idea. I think I would need a large open area and I may try it later.
                • PRG
                  • Nov 2006
                  • 617
                  Howdy sir,
                  Define lever moves to easily. Do you mean the arm attached to the worm on the outside of the primary, with 16 clutch springs it should never move easily, requiring a crescent wrench to actuate if the linkage is disconnected. Either it needs to be adjusted to actually engage the worm to draw your pressure plate off or if that adjustment yielding nothing, then among other possibilities you’ve had total throw out bearing failure, your clutch stack height is out of spec or the large nut securing your clutch basket to the drive side trans bearing is backing off. I’d remove outer primary and then trans lid in that order.
                  Fours routinely lock their clutches in long storage, do not drop your machine off the center stand regardless of the fact it is a two man operation to undertake with precarious operator control, you risk breaking off the two cast steel mounting ears in the frame. If this clutch has truly dry welded itself, a first for a Chief I must say, merely start it, drop to a low idle, paddle off down the street with your feet while in the saddle, snick it in first gear and then commence rolling the throttle on and off with the clutch pedal disengaged. Has worked on my 440 for 25 years but I think your problem may lay elsewhere with this Chief.
                  Cheerio,
                  Peter
                  #6510
                    • 8248
                    Line up hay bales on both sides of the launch, Larry!
                    PS: Its easier to do as Tom recommended.
                      • 971
                      Why drop it off the stand running in gear when I think you could hit the brake with the clutch in.But like Peter said if the lever and pedal dont feel normal taking the cover off would be next step.
                      • cdf6333
                        • Nov 2008
                        • 273
                        But you have to start with the proper adjustment. Take the cotter pin out and see where the free play ends. Very possible that they mis-installed the arm on the hex. Adjusting takes 3 minutes. a 1/2" wrench and whatever to pill the pin.
                          • 1676
                          Good first step right there!
                          Chris Haynes has years and years riding motorcycles and more skills than I'll ever have, I'd be really hesitant to do it the way Chris would...too many things could go wrong!
                          • larrymgibson
                            • Aug 2015
                            • 70
                            I removed the cover and examined the clutch and everything looked normal. I hate to admit it, but the worm just wasn’t adjusted properly. It is now back together and working properly without the engine running. Now I have to deal with a gasoline leak. Thanks everyone for the encouragement.
                            • larrymgibson
                              • Aug 2015
                              • 70
                              Leaks have been addressed. It is about 50 degrees and cloudy right now. I plan to ride it today for the first time in 26 years. It broke down in Sturgis, SD in 1992 after riding and tent camping from Indiana. Wish me good luck. I will post a photo and video.
