1947 Chief Linkert M344 Jet
  • larrymgibson
    • Aug 2015
    • 70
    I have the original (I think) Linkert M344 carburetor for the 1947 Chief. It has run in the past after a carb rebuild, but only about 1500 miles. It sat in my living room for 20 years. Then the engine and transmission were rebuilt. Then I took the whole motorcycle apart, cleaned and painted it. It is now all back together. I have good spark, but when it wouldn't start, I started inspecting the fuel system. Took the carb apart to inspect and clean. Found that I had lost the spring that holds the emulsifier (aka fuel feed nozzle) up into the venturi. Took care of that, but in looking at various YouTube videos I see that where I have 2 plugs in the casting that rests in the float bowl, some have a jet in one of those holes. I don't have a leftover jet and I had just enough plugs for the holes. I will attach a photo. Should I have a jet in one of these holes?
    Just plugs, Larry!
    Your bowl gasket is a little fat for a model that didn't use one, and your float is a boatanchor.
    But it should still start even with the nozzle dropped; Run crappy though...
    So please test your manifold while the carb is off: http://virtualindian.org/11techleaktest.html
    Good luck!
    PS: U-tube is the fast lane on the miss-information highway.
    • slamiste
      • Mar 2010
      • 260
      The set up shown in your picture looks correct to me.
      Steve Slaminko
      • larrymgibson
        • Aug 2015
        • 70
        After several parts replacements (including the boat anchor float), the carb is functioning properly and the Indian started and ran for the first time in 26 years! Now I have questions about proper lubrication in the engine, transmission/clutch.
