1940 chief blowing blue smoke
  • pisten-bully
    replied
    I had a '40 Chief that would occasionally wet sump. The engine would get lazy, hot, and smoke. . . Just like a girlfriend I had
    I just hit the invisible "LIKE" button on that comment!
    replied
    Like both Toms said, check your crankcase to see how much oil comes out, and then monitor it. I had a '40 Chief that would occasionally wet sump. The engine would get lazy, hot, and smoke. . . Just like a girlfriend I had
  • Tom Lovejoy
    replied
    yep, I would check for wet sumping first off. Can you see oil returning to your tank with the cap off ? don't make a mess :-) Good luck
  • tfburke3
    replied
    check how much oil darins from the crankcase or if you have a level plug above the drain see much comes out there to verify your not wet sumping.
    Check compression,go from there.
  • jn1972
    started a topic 1940 chief blowing blue smoke
    I have a 1940 chief ,that was rebuilt 2 years ago ,just took it for a ride and it started blowing out blue smoke ,motor was completely gone thru 2 years ago ,any ideas what I should check first thanks
