1940 chief blowing blue smoke
  • jn1972
    • Oct 2013
    • 84
    I have a 1940 chief ,that was rebuilt 2 years ago ,just took it for a ride and it started blowing out blue smoke ,motor was completely gone thru 2 years ago ,any ideas what I should check first thanks
    • 968
    check how much oil darins from the crankcase or if you have a level plug above the drain see much comes out there to verify your not wet sumping.
    Check compression,go from there.
    • Tom Lovejoy
      • Aug 2006
      • 951
      yep, I would check for wet sumping first off. Can you see oil returning to your tank with the cap off ? don't make a mess :-) Good luck
        • 6034
        Like both Toms said, check your crankcase to see how much oil comes out, and then monitor it. I had a '40 Chief that would occasionally wet sump. The engine would get lazy, hot, and smoke. . . Just like a girlfriend I had
          • 1676
          I just hit the invisible "LIKE" button on that comment!
