Trying to find the timing marks I have yet to find the + and the I, but have found a mark that looks like a $. Granted, I am trying to bump the motor and look through the timing hole at the same time, but what does the $ mean.
1945 chief timing
Originally posted by fizz View PostReally, Eric, that is the timing mark? I have a 1944 manuel that talks about using the I mark.Pisten Bully is Harry Roberts in Vermont.
I had a 1940 Chief which has no timing hole for viewing the flywheel. I found TDC, and BTDC when I had the motor out of the frame and was able to measure piston location with the head off. I marked the flywheels with a drill point through the crankcase drain plug, under the primary case. . . . Pain-in-the-ass !Eric Smith
Folks,
Piston position on an installed motor is no problem, as long as you can accurately turn the motor back and forth, such as at the motor sprocket.
(That is also the most convenient place to attach a degree wheel.)
A drop of colored oil in the tube of this simple device screwed into the sparkplug hole will rise and fall with the piston.
At its highest point, set your degree wheel to TDC.
....CottenLast edited by T. Cotten; 07-21-2018, 10:37 AM.AMCA #776
Well, timing got easier anyway, going to be able to measure how far the piston is down in the cylinder, cause when I had my finger over the front spark plug hole the compression felt less than the rear, pulled the head, and got a scored cylinder. Should a guy make any modifications as far as compression, etc, while it is apart? Stock is fine, but since I can get 91 octane easy, bump up compression or leave it alone. I do ride it a lot. What was the difference between a stock and a Bonneville engine besides cam.
Originally posted by fizz View PostWell, timing got easier anyway, going to be able to measure how far the piston is down in the cylinder, cause when I had my finger over the front spark plug hole the compression felt less than the rear, pulled the head, and got a scored cylinder. Should a guy make any modifications as far as compression, etc, while it is apart? Stock is fine, but since I can get 91 octane easy, bump up compression or leave it alone. I do ride it a lot. What was the difference between a stock and a Bonneville engine besides cam.
Originally posted by exeric View PostI had a 1940 Chief which has no timing hole for viewing the flywheel. I found TDC, and BTDC when I had the motor out of the frame and was able to measure piston location with the head off. I marked the flywheels with a drill point through the crankcase drain plug, under the primary case. . . . Pain-in-the-ass !
Originally posted by tomfiii View PostDid it not have the timing hole plug just above the drain plug,they look the same?Compound that with trying to bump the flywheel into position, and your neighbor's kids will hear your complete collection of dirty words
I think it was 1944 when Indian put the timing hole in the 'right' place on the crankcase, and you have to wonder why it took them so long.
Originally posted by fizz View PostI decided to stay stock. No need to modify it.Eric Smith
