Originally posted by samsmc1
View Post
I have no experience with Eastern cylinders.
There were extensive discussions on the VirtualIndian yahoo group about re-manufacturing the Eversure Auto Agency castings, which were probably the same, but I didn't pay attention.
Back to securing a sleeve,
I was schooled that the light press was essentially for heat transfer, as the enormous surface area is plenty of resistance to movement, even with a micro-fine finish. Cast iron doesn't shrink when over-heated like a tool steel, and the expansion coefficients of a cast iron sleeve in a cast iron cylinder are identical.
Perhaps Loctite offers a similar compound to Seal-Lock, but beware that their saccharin formulae may insulate instead of conduct, if they survive the heat.
Here's a sleeve that failed Folks...
(Sorry its upside-down; the burnt portion should be at the top.)
The reason it failed was the shoddy borejob in the casting. Although the sleeve never moved, there was not enough contact for heat transfer, with the voids insulating it further.
