Was wondering if anyone has taken apart a set of chief tanks, I have a set of 48 tanks I have apart but I am a little stumped on getting the mounting brackets off,look to be set on studs and possibly soldered on but I'm not positive, anybody know for sure?
Chief tanks
My advice is to buy a set of welded Chief tanks from Iron Horse Corral. They're a bit pricey, but no leaks, no fires, no worries. Original tanks can be restored, and that should include re-tinning the inside surfaces. This can be expedited by getting the tanks tin plated, or copper plated to make it easier to bond lead solder. The problem with this is minute inclusions, and contamination that will just rust later on, leak, and ruin a paint job. If you were fixing a tank for an ACE, or early motorcycle gas tank that can't be replaced, you would have to proceed; but late Chief tanks by IHC are superior to original, and easy to obtain. Your time, and health is worth consideration. Just something to think about.Eric Smith
I've rebuilt soldered tanks, and did a few for late Indians. To successfully re-solder the seams, the steel has to be hospital clean, and that can't be over emphasized. There are a lot of ways to clean metal, and you'll probably try them all. I do have a suggestion that I have used on every soldered tank I've messed with. I make a plywood form and cut out an opening that is bigger than the tank profile. I make a bunch of aluminum angle brackets tapped for 1/4" hex head bolts, and use them to press the tank shell against the inside panel. I've attached a crappy drawing of the fixture concept. I use 50/50 solder, liquid flux, and big copper solder irons that I heat with a propane torch. Don't put a flame to the metal. I apologize if I'm telling you things you already know.Last edited by exeric; 02-15-2018, 08:00 AM.Eric Smith
The front bracket and rear tab are spot welded to the back plate.I don't think you need or want to remove them.
Also Indian tanks for 50-53 are brazed together so you may want to try brazing if you completely diassemble to remove all solder.
The advise for a jig is a must.
You might find it in the library or archives for the club. It is about 8 or 9 pages long and posting pictures is not my strong area. But I have made a copy of it and could make more for you if you can't find it. You can PM me and we can go from there. I know that I gave the correct issues because I wrote it down when I made my copy. It is quite detailed.Jim D
I remember that issue, Jim. Very good article, and some great tips on repair. However, it's strictly a lead repair, and no welding or brazing was done in the restoration. The guy who did the repairs was a real craftsman and I heard that he was overwhelmed with requests from people who wanted him to fix their tanks.Eric Smith
