Will CDE chief motor fit in 1946 frame?
  • preacher53
    • Feb 2015
    • 6
    I have indian chief cases stamped CDE without serial numbers--- i am assuming its a 1945 chief motor,,,will it fit in 1946 chief frame? thks
    • 971
    any chief motor from 1934-1953 is interchangeable with frames from the same year range.
    tom
      • 6045
      You can run into problems with the chain adjustment screw on the primary. Often times, motorcycles can become a mélange of parts from many different years. Just look at the adjustment screw angle, and your frame. It will be obvious.
        • 971
        Good point.The inner primary cover and the trans mainshaft and sprocket driver are specific to either rigid or plunger frame,but basic engine mounting in frame is the same.
