36 T Oil Lines?
  • Knotthed
    • Jul 2008
    • 195
    36 T Oil Lines?
    Does anyone have any 36 Chief T Oil lines or plans for such?
    Thanks.
    D.J. Knott
    AMCA #10930
  • Rollo
    • Nov 2008
    • 599
    Mine have been eliminated as a lot of them were back in the day as they were prone to leaking. Might check Greer to see if they offer them.
    Tom (Rollo) Hardy
    AMCA #12766
    • Knotthed
      • Jul 2008
      • 195
      No go from Greer. He has clamshell covers without the hole for the T lines. Mine were eliminated also, but I thought I would like to at least have one or a pattern.
      D.J. Knott
      AMCA #10930
      • gsottl
        • 216
        I am quite certain that Indian used the same T-piece as on the gaslines for the T-oillines:
        Rgds,
        speingfield1901
        • Knotthed
          • Jul 2008
          • 195
          I have not seen any pictures that support the use of the gas line T. It might be a solution, but all of the pictures I've seen, seem to be a tube into a tube at 90 degrees.
          The real question is what do they look like where they enter the clamshell valve covers? you cannot see that on assembled units.
          D.J. Knott
          AMCA #10930
