1940 Chief 340 - Front Fender Light Location
  • NiteOwl
    • Jun 2011
    • 247
    What is the correct location for the front fender light on a skirted chief, Note this is the 1940 Chief which I think is different from the 1946 and later front fender light positions?
    I know the 46 and later have a first hole located approximately 9.5" from the tip.
    I suspect the 1940 first hole is located 11.5" from the tip but would like confirmation.
    Bob
    Bob Beatty
    AMCA 19209
  • 20scout
    • Dec 2005
    • 238
    On my 40 Chief the front hole is 10 1/4" from the tip.
    20scout
    • ryan
      • Mar 2017
      • 610
      I do not think my 42 chief even had a fender light out of the factory, Didn't they originally come out later than 1942?
      • Green Indian
        • Apr 2014
        • 303
        They had them in '42 Here's a pic of my 42 Chief.
        AMCA # 3233
        • NiteOwl
          • Jun 2011
          • 247
          I am not 100% certain BUT I think the 1940 front fender changed in 41 slightly, I think it was made a little smaller or shorter.
          Bob Beatty
          AMCA 19209
            • 1675
            ....and the fender skirts in 1940 were flatter, later fenders had the skirt bulge out at the seam. Good question about 1940 fender lamp! I wonder myself!
            The CAV's didn't have fender lamps, but you see them on the civilian ones....restored civilian ones.
            • 39ChiefBonnie
              • Feb 2014
              • 48
              Hi Bob, so what measurement did you come up with? I need to drill holes in my 1940 front fender. Thanks Matt
              • NiteOwl
                • Jun 2011
                • 247
                Hi
                I finally put it 9 1/4 tip to first hole center. Like the look fender light is aligned nicely at this position. I also found a technical drawing (see attached) that told me approx 9 1/2. The wording on the drawing was "first hole approximatly 9 1/2 from fender edge."
                as well as most fenders on others bikes I found were this ~9 1/4 measurement.
                Http://www.theironhorsecorral.com/co...lightholes.gif fenderlightholes.gif
                Bob Beatty
                AMCA 19209
                  • 6020
                  Hatfield's book lists the front fender light as standard for all models except the 30.50 starting in 1940. Indian's literature shows the fender light starting in 1940. Regardless, I think they look great, and I'm putting one on my '41 SS.
