18 in. Rear hub lace up pattern 1938
  • Americanrider
    Injun nut
    • Nov 2009
    • 40
    I'm having issues with the correct lace up on a '38 rear hub and wheel. It's a 18 inch repop rim, spokes and hub all from from Greer's, the spokes are Buchanan's sold through Greer and I confirmed they are the correct set/part number. I was told the 18 inch is a 1 over 4 lace pattern. If anyone has a 18 inch Rear rim they can look at and give my the correct lace pattern it would be very helpful.
    Looking at it from the Non-brake side, Valve Stem marked with blue tape. I need to know what is spoke #1, 2, 3, 4. and I should be able to figure it out from there.
    Merry Christmas and Thanks,
    ~B
    Boone member #15941
    1946 Chief Basket builder
    1939/47 Chief Bobber
    1953 Blackhawk Chief
    1997 HD Roadking
    • 971
    ~B
    Looking at nos wheel
    1 inside brake side
    2inside non brake side
    3 outside brake side
    4 outside hub side
    Merry Christmas
    • Americanrider
      Injun nut
      • Nov 2009
      • 40
      All done, thanks
      Boone member #15941
      1997 HD Roadking
        That is a rim for a 45" front wheel.
        • Americanrider
          Injun nut
          • Nov 2009
          • 40
          As I stated earlier, "All the parts came from Greer's" maybe you should tell them they are selling 45" parts.
          Boone member #15941
          1997 HD Roadking
