1922 Chief gearbox bearing
  • hairynob24
    • Feb 2011
    • 348
    G,day does anyone know where i can buy a bearing for my 22 Chief . Its the one on the primary side , my old one has Made in Italy RIV OFF VILLAR PEROGA 6AE ? thats all the info thats on it , the 22 bearing is located from the primary side not from the gearbox side , this is a thin bearing , does anyone know of these numbers on the bearing , Rob
  • gharper
    • Nov 2009
    • 528
    Rob, Can't help with the bearing exactly, but..... Try the Big Chief forum on Yahoo: https://groups.yahoo.com/neo/groups/...torcycles/info
    Also, if it is the same narrow bearing as on the drive side, I believe they are available from Randy Walker: https://groups.yahoo.com/neo/groups/...torcycles/info
    Of course, Kent Thompson in new Hampshire is always a sure bet for early chief parts. He is listed in the AMCA roster, contact me by pm if you can't find his number.
    Gene
    • gharper
      • Nov 2009
      • 528
      Rob,
      Here is the early Scout primary side bearing, not sure if the same, again from Walker:
      And the correct link to the drive side bearing, (sorry for the confusion, forgot to proof read) http://walkermachine.com/drivegearba...rrow-10mm.aspx
      Have you tried a good bearing supply house? Probably not a particularly odd size, but beware, that is a radial thrust bearing! If you replace it with a non radial thrust bearing, it won't last very long because the helical cut primary drive gears want to push and pull the clutch basket in and out with every twist of the throttle!
      Gene,
      • hairynob24
        • Feb 2011
        • 348
        Gene thanks ,i have seen Walker Machine an email to see if he knows ,cheers Rob
          • 6034
          If Walker Machine could get that bearing, you can too Rob. An interesting fact (with a few exceptions). Machines are designed around bearings, and not the other way around.
