Need a part ID
  • John Guntner
    • Feb 2007
    • 192
    Need a part ID
    So I've rebuilt my motor and now I've found a spring which I don't know where it came from. The motor or it just happen to be in with the motor nuts and bolts. Does anyone know if I've missed something in the assembly? Thanks.....John
  • Yellow53Chief
    • Apr 2015
    • 116
    Hi,
    I don't recognize it as an engine spring, though it might be. It looks something like the fuse spring that is in an electrical in-line fuse holder (possibly aftermarket). What I have seen is that an in-line fuse holder comes with a variety of springs to work with different fuses. The ones that are not chosen, tend to be kicking around afterward. It is a mystery.
    • harleytoprock
      • Apr 2003
      • 374
      Carburetor main nozzle spring ?
      • Yellow53Chief
        • Apr 2015
        • 116
        Hi,
        I don't think it is Linkert carburetor nozzle spring. That spring is longer than a penny is wide. Here is the nozzle spring from Jerry Greer. A small short spring is used between the primary chain shoe and shoe arm, but that spring typically doesn't have the tightly wound ends. Hmmm.
          • 2034
          My brother worked in a shop,a guy kept giving him a hard time about being a not good mechanic.The guy brought in a Vespa & tore the carb apart,my bro thru an oring in his box of parts.He got it back together and couldn't finger out the oring.He fretted for a couple weeks ,then bro thru the oring in the street & told him to start it!
            • 8236
            John!
            It more closely resembles a carb detente spring, however they did not have as many close winds at each end, and they were "beryllium".
            • cdf6333
              • Nov 2008
              • 273
              • Yellow53Chief
                • Apr 2015
                • 116
                cdf6333 is the winner!! What does he win? Kudos for sure.
                • Paultrehberg
                  • Nov 2015
                  • 62
                  Could be the spring that tensions the ball for the choke butterfly positioner.
                    • 8236
                    Yellow53Chief!
                    CDF6333's looks long to me.
                    I collect pen springs out of dumpsters regularly, because they are usefull, yet I have never found one as short as John's, nor of that stout of wire.
                    But I have scrounged similar from discarded screwguns, along with 5/32" balls!
                    (AMCA "correct".)
                    PS: Paul!
                    The choke mechanism is what I called a "detente". Sorry I don't remember where I got the term.
                      • 4788
                      A "detent", and "detente" are quite different terms. But we get the gist of it....
                        • 6020
                        Some times logic can be your worst enemy. Great story Roger
                        • John Guntner
                          • Feb 2007
                          • 192
                          Well that was fun. I should get some sleep tonight. I was thinking the spring for the primary chain shoe mechanism but I think it's to small. Thanks everyone. Ride On John
                          • RonH
                            • Jan 2016
                            • 213
                            I am thinking this:
