I am regreasing the bearings on my 1940 chief ,when i disasembled the rear hub ,there was a piece of shim stock around the bearing ,with the shim stock in place the bearing is tight in the hub is it ok to leave the shim stock in there thanks jerry
1940 chief rear brake hub
