speedo drive question:
  • john fretschl
    • Aug 2006
    • 73
    am about to close up the drive unit after replacing the speedo drive gear. It didn't seem like when I took it apart that there wasn't much grease in it. My question is should the unit be packed with full of grease?
  • tfburke3
    • Oct 2011
    • 965
    Yes that's why the grease fitting.I dont think you can over grease it.Also check the engagement of the ring and pinion.
    usually the ring wears a groove in the potmetal housing allowing it to move tighter into the pinion and then the steel pinion wipes out the ring.Some people shim the ring gear,or replace housing.
    Like a car rear end you can use the grease to show gear mesh and you should have some very little lash.
