Why replace rollers with bushings in 1947 girder fork?
  • larrymgibson
    • Aug 2015
    • 70
    I have read matter-of-fact suggestions to replace the roller bearings in the girder fork on 1947 chief with bushings. I'm in the process of re-assembling my 1947 chief. The front suspension seemed fine to me the last time I rode it. (23 years ago) It has been stored in my living room since taking it off the road. I had just completed a trip of 1500 miles when the engine went bad.
    The rollers are all there and seem fine. Should I replace them with bronze? Why?
    Thanks for the info.
    Larry Gibson
  • fillibuster
    red dog
    • Aug 2009
    • 934
    There's nothing wrong with good parts, imo. If the bearings feel good with the shackle rod, run it. If there are rough spots in the rotation, or visible wear areas in the rod, replace with a new rod.
    I hope that the new rods are hard enough to handle the bearing rollers.
      • 1676
      Don't '47 + forks also have grease zerks on them for the cross link bearings? I'm with Fillibuster, keep 'em if they're good!
        • 971
        Jerry Hatfields Indian Resto guide says 48 zirc grease fittings introduced to accommodate bushings.
        I would also use if all the shafts and bearings look good,but I have never taken apart a roller shaft that wastnt dented up from pounding by the small surface contact of the rollers.
        Bushings also can be line reamed.
        • tomfiii
          • Jun 2007
          • 316
          You will probably see wear spots from rollers. The problem is that they do not rotate very much and roller will stay close to same position and mileage pounding will eventually cause problem.
          • larrymgibson
            • Aug 2015
            • 70
            Thanks for responses
            I'm
            Larry Gibson
            Thanks for the suggestions. I will inspect the rods for wear.
            • 1950Panhead
              • Jun 2010
              • 343
              The rollers put dents in the shafts, the bushings have five times the surface contact area lasting much longer.
