Replacing throttle cable
  • Temple
    • Nov 2014
    • 97
    i assume this isnt difficult but i havent done this on the indian. Are there any surprises or is it as easy as it looks? 1 hour tops?
  • hairynob24
    • Feb 2011
    • 348
    Temple are you doing the inner or outer cable ? either way i would pull the outer out first than put the new other on , secondly do the inner using the outer as a guide or vise vesa ,Rob
    • fillibuster
      red dog
      • Aug 2009
      • 934
      I've managed replacing the inner with the outer still in place. Had to work the bends a little.
      • Temple
        • Nov 2014
        • 97
        Inner and outer? Maybe this will be longer than an hour. My only experience was my old panhead. I only see one throttle cable for my 41 chief.
        • hairynob24
          • Feb 2011
          • 348
          Temple , what i meant by inner and outer is the thin wire run in a protected out , you may need to only do the thin inner only , sometimes the outer will come lose at the hand grip end , its not a big job but can be a pain in the ass ,well worth doing for a nice easy flowing control ,a bit of oil or grease on the inner will help it get through ,cheers Rob
          • Tom Lovejoy
            • Aug 2006
            • 951
            Have done it along side the road in less than an hour, I keep one in my saddle bags, just in case ever since. I have done two on rides for others with my spare. So far it has never happend to me when I have had the spare in my bags. With the tools handy in your driveway. I would say an hour or so. Don't think I can do much of anything quicker than that :-) good luck
            • Inchief
              • Jan 2014
              • 35
              I have been using stainless steel for the inner solid wire. Figure it would not rust and hold up better. Ordered some from McMaster Carr.
              • Yellow53Chief
                • Apr 2015
                • 116
                Hi,
                Here is some handlebar information that may help. Indian handlebar issues - 1 of 4.jpgIndian handlebar issues - 2 of 4.jpgIndian handlebar issues - 3 of 4.jpgIndian handlebar issues - 4 of 4.jpg
                • Temple
                  • Nov 2014
                  • 97
                  Thank you.
                  • TH47Indy
                    • Jun 2016
                    • 187
                    Originally posted by Yellow53Chief View Post
                    Hi,
                    Here is some handlebar information that may help. [ATTACH=CONFIG]15006[/ATTACH][ATTACH=CONFIG]15007[/ATTACH][ATTACH=CONFIG]15008[/ATTACH][ATTACH=CONFIG]15009[/ATTACH]
                    I know this is an old thread, but just found it and found some info I didn't know about setting the limits for the carb and spark advance, perfect timing as I'm just running and attaching the cables now.
                    Thanks!
                    • Temple
                      • Nov 2014
                      • 97
                      Thanks!
                      Thank you for this information. Appreciated.
