motor info:
  • john fretschl
    • Aug 2006
    • 73
    motor info:
    can someone explain to me when did they started to put Bonneville motors in Chiefs? Also what are the differences between the stock 74Ci. ?
  • bstevens479
    • Jun 2011
    • 109
    Hi John 1940-1948 pistons different, slightly higher compression, heavier valve springs,more aggressive cams & followers special carb. mods.
    • someozybloke
      • Oct 2013
      • 68
      I have seen a sales brochure from 1939 that lists the Bonneville option.
      339 "B" - $405.00
      339 "M" - $425.00
      339 "BM" - $450.00
      might have seen it on another forum.. just remember seeing the prices.
      • Lonewolf_51
        • Jan 2010
        • 76
        Magneto, larger cylinder head depth, high lift cams, 350 and up carb, or BONN Carb.
          • 8246
          A mystery Folks,
          Is why the 1940 Motorcycle Parts Catalog lists Bonneville carburetor parts, when apparently Schebler didn't produce any.
          Any fossil evidence would be greatly appreciated!
          • someozybloke
            • Oct 2013
            • 68
            Grabbed a couple of images from the 1936 - 1942 parts Catalog that I have.
            Bonneville Parts were offered for
            1939-1942 Chief 74"
            1939-1942 SS 45"
            1940-1942 45"
            Here are some of the screenshots
            Bonneville Cylinders.JPGBonneville Heads.JPGBonneville Manifold.JPGBonneville Pistons 74.JPGBonneville Heads SS.JPG
            They offered a Bonneville replacement for the Marvel Carb as well.
            Has anyone got a Bonneville Manifold, how different is it from the standard manifold.
            Mike
            • someozybloke
              • Oct 2013
              • 68
              Missed the attachment for the Carb
                • 8246
                Someozybloke!
                That carb listing is similar to the '40 book (attached);
                The mystery is why there were Bonne carbs listed for '39-only twins before Linkerts were introduced for Indians in '41.
                Nobody seems to have ever encountered a Schebler stamped 'Bonne', and I have never encountered a 1 1/8" Schebler venturi.
                Listing in the '42 catalog as "replacements" is not such a mystery.
                I have never found much of a difference (other than cast iron vs aluminum) in Chief manifolds.
                Sport Scouts do vary greatly in porting, however.
                You confuse me about the 'Bonne' Marvel, as I do not see the '36-only Four model listed.
                ( But I have encountered those with differing jets... for what that's worth.)
                .....Cotten
                PS: All Bonnes I have encountered appeared to be typical for Linkert's '40 or later productions. If a '39 Indian Bonne Linkert exists, it would be nickel, with the "4-line script" on the side.
                • someozybloke
                  • Oct 2013
                  • 68
                  Thanks for the update Cotten, it fascinates me that a company has such poor record keeping, or I guess a lot of it was lost or throw out when the company ceased trading.
                  It's like doing a jigsaw that is missing some of the pieces and you have no picture to work from, so really don't know what is missing anyway.
                  Mike
                    • 8246
                    Forensics is our task, Mike!
                    Parts books from many marques are questionable upon specifics, and the Indian '36-'42 is often cited for blatant flaws.
                    Once again, if anyone has examples from the 'fossil record' about pre-'41 Bonne's, please post us with clear photos.
                    As a student, I will greatly appreciate it.
                    • Lonewolf_51
                      • Jan 2010
                      • 76
                      I have found eight factors that comprise a Bonneville Indian. Plus, much higher top speed than the Standard Chief with 92 mph.
                      1. Magneto ignition
                      2. Cam measurement-Lobe Height=1.575" (standard=1.510")
                      Base Circle Dia=1.100" (standard=1.110")
                      3. Cam Lifters and Followers.
                      4. Heads-3/4" reach to spark plug (standard-1/2")
                      5. Kickstarter pedal-11 tooth (standard 10 tooth). Kickstarter Gear-28 tooth (standard 32 tooth).
                      6. Linkert Carburetor-Stamped M-BONN, and I believe is larger than Standard Indian Chief. Linkert Stamped 350-352 will also work.
                      7. Heavier Valve Springs.
                      8. Bonneville Cylinders intake measurement different than standard Chief.
