Needed some advice on my 41 Chief bob job, I'm bobbing a 41 chief that is a mag the problem is the mag just won;t fire right & I am constantly being told I should just convert it to a distributor & be done with it, Question is how difficult is it to mount a autolite into a mag Distributor? I have never attempted this so I'm not sure how to go about it. Do I need a new pump or can I add the dist sleeve & such to the mag I have?
Does the Mag pump have a drive gera in it for the Dist or does the pump have to be removed & modified , I'm ok with the rest of the process, ( Coil, Generator, reset timing) My lack of Pump & Distributor knowledge is my fear in attempting this, Any detailed info would be great & any info with pictures would be fantastic, I am always open to suggestions & advice. Thanks
