Chief Seat Post Adjustment
  • Chief Seat Post Adjustment
    I have a late 39 Chief and the seat post was replaced and seems not to be moving. I am not sure how to adjust it to get it moving. I don't think it is ceased in the bushing. Thanks for any suggestions.
    It may be bent, remove it and check it with a straight edge. Another problem may be that a spring cracked and is jammed up in the lower tube. Pull the whole thing out and clean/inspect it, should be a easy fix.
    Boone member #15941
    1946 Chief Basket builder
    1939/47 Chief Bobber
    1953 Blackhawk Chief
    1997 HD Roadking
      I realized it was stuck in down a few taps with a rubber mallet and it work fine thanks for the help.
