Transmission Case Oil Level Plug
  • John Guntner
    • Feb 2007
    • 192
    I know a lot of you have drilled and tapped a fluid level pug in your transmission cases. You can drain your transmission and then fill to the level on the plug. My question is; where does that hole go that you tap? Is it that little boss on the side of the transmission case? I don't want to screw this up so any help would be appreciated. Thanks.
    • 971
    The trans level plug is for later powerplants or those modified to split the trans and primary oils.Otherwise why bother,just drain and change the primary/trans, at the same time using level hole in outer primary.The level hole would go in the boss you mentioned.
    • John Guntner
      • Feb 2007
      • 192
      That's what I'm thinking and thanks by the way for your response. My primary is sealed off from the transmission so while I have it apart I will drill and tap a hole so I can make my tranny oil changes easier. I hope.
      • Skirted
        • Sep 2012
        • 710
        John,
        You may find this thread helpful.
        Jason Zerbini
        #21594
