38 Chief schematic/wiring help needed
  • 38 Chief schematic/wiring help needed
    Wiring a 38 Chief magneto motor set-up & would be grateful if anyone can offer a schematic or point me in the right direction. Also, if anybody can tell me the mounting location of the terminal block, that would be a big help as well. Thanks.
    Don't know if this will help, but here's the schematic from the 1933 riders manual.
    littlejohn
      Thanks littlejohn, that helps. Have the 51 riders manual schematics which shows back to 41-42 models so with the 33, I should be close.
      Now if I could find out the correct mounting location for the terminal block I'll be in good shape.
        I have this drawing which is supposedly a 1939 diagram.
          Mike[ATTACH=CONFIG]13515[/ATTACH]
          Mike you ol' cobber! Thank you Sir!!! That's perfectly what I need! 38-39 are the same except for the size of terminal block as far as I know.
          Now if I only knew the mounting location for the terminal block itself on the rear fender I'd be golden.
            I put a couple terminal block pics up as a separate thread
