Wiring a 38 Chief magneto motor set-up & would be grateful if anyone can offer a schematic or point me in the right direction. Also, if anybody can tell me the mounting location of the terminal block, that would be a big help as well. Thanks.
38 Chief schematic/wiring help needed
Mike you ol' cobber! Thank you Sir!!! That's perfectly what I need! 38-39 are the same except for the size of terminal block as far as I know.Originally posted by someozybloke View PostI have this drawing which is supposedly a 1939 diagram.
Mike[ATTACH=CONFIG]13515[/ATTACH]
Now if I only knew the mounting location for the terminal block itself on the rear fender I'd be golden.
