46-48 Girder Front Link Adjustment
  • Fredthecat
    • May 2013
    • 25
    Any thoughts/experience on how to adjust front fork links other than follow instructions in manual?
    Loosen jam nuts, tap left end to loosen taper, adjust shaft in/out until thrust washers slightly turn, tighten jam nuts.
    Should all thrust washers (right and left ends) still turn after jam nuts are "tightened"?
    When I tighten jam nuts, right washer no longer turns, left barely. Which shackle to adjust first? Top front, top rear?
    Wheel on ground or front wheel off ground?
    Fredthecat
  • phillie
    Young Blood I think..haha
    • Jun 2011
    • 97
    you want all of the thrust washers so you can turn them slightly by hand. I adjusted mine with the front wheel off the ground. I don't think it matters in whick order you do it in. I just snugged all of mine up then adjusted them.
    • Fredthecat
      • May 2013
      • 25
      Thanks for the help.
      During initial assembly, how far should bolts be screwed into/through right side shackle?
      Is the photo on page 49 of repair manual backwards? It shows threaded bolt to right (left side of bike).
      • cdf6333
        • Nov 2008
        • 273
        I do the job without the o-rings/felts, makes it a lot easier. Get some modern nuts so you don't wear yours out doing this. 7/16 x 20 and 1/2 x 20. Then I break the tapers and stick the o-rings/felts in, after adjustment. This is the easiest way to grease the 46-47's too, break the taper, pull out the u shaped piece and stick some grease in, re-install and done.
        Probably easier to do the adjustment dry too.
        • tomfiii
          • Jun 2007
          • 314
          It is correct to look down on bike from seated position, which is how the shaft looks from above.
          • Fredthecat
            • May 2013
            • 25
            Now it makes perfect sense. Thanks
