47 Chief main ground point
  • Fredthecat
    • May 2013
    • 25
    Thanks.
    I had in mind putting a 20A push/pull aircraft circuit breaker in line, negative battery lead to ground. Mounted on bracket on backside of primary case, below generator belt, pointed aft. Pull breaker, cuts current to main ground. Use this on Model A Ford and simply lift hood and pull breaker when parked.
    Also baffles would be thieves.
