Common, Grease those bikes!!!
  • NiteOwl
    • Jun 2011
    • 247
    Just opened up the rear shocks on this Chief and was amazed, there are zerks on the top and bottom, there was enough grease to fill the zerk (maybe a pump), yet I pulled the shocks apart and could blow through the fitting the nipple screwed into all the way to the other side, absolutely no grease, I have found every fitting to be like this, I am lucky that not many miles were put on since it was last assembled, however I can't leave anything to chance. Everything is coming apart but man what a pos it would have been if all had rusted solid.
    Bob Beatty
    AMCA 19209
  • hairynob24
    • Feb 2011
    • 348
    NiteOwl,i have just re assembled mine today,how much grease should be in the plunger? the shaft is full but how much is required ?the hole unit or not .Rob
    • NiteOwl
      • Jun 2011
      • 247
      I am not going to pretend that I know the exact answer to this, hopefully an experienced rider will jump in.
      I would suggest the spring assembly and inner housing be lubricated well with grease, also ensure the shaft is full, (my new to me bike was dry), then follow the manufacturers greasing schedule. I would then use 3 strokes of the grease gun following that schedule. (I am open to being corrected and would welcome opinions.)
      Bob Beatty
      AMCA 19209
        • Feb 2003
        • 5353
        I went through what left I have for Indian literature and every mention says simply to grease it and do it every thousand miles. I think your suggestion seems reasonable Bob. Where's that Red Fred when ya need him?
        Cory Othen
        Membership#10953
        • hairynob24
          • Feb 2011
          • 348
          Ok no reply yet ,come on you Indian people ,how much grease is needed in the plunger ?
          • cdf6333
            • Nov 2008
            • 273
            I'm hoping for the answer too. This is something I never thought about. I figured like old Brylcreem, " a little dab will do ya". It's not filling anything like a ball joint, just lubing the shaft.
            • NiteOwl
              • Jun 2011
              • 247
              I will dive in again. Upon assembly grease the outer shaft, fill the inner shaft (grease-way) and zerks with grease. Assemble and follow the recommended grease schedule (apperently 1k mikes) and then give it 1 shot at each zerk. Can't go wrong.
              Bob Beatty
              AMCA 19209
