Distributor shaft tollerance
    • 6019
    My 1940 Chief has, what seems like an excessive amount of slop in the distributor shaft. To me it looks like about 10 degrees of free play between the slop in the rotor, and the slop in the dist. shaft key where it goes into the pump. Is that normal ? It runs okay, but I've noticed a jerkiness in certain power bands.
    • 6019
    Nevermind, I found the information I needed in the military Chief manual.
      • Feb 2003
      • 5353
      Glad you got it figured Eric. I did some scouring in my books and came up short. That's what I get for letting literature go with the sale of an Indian!!!
      Cory Othen
      Membership#10953
        • 6019
        I've done the same thing Cory and regretted it. By the way, my book said there should be minimal movement in the dist. shaft and rotor, and that the shaft should be replaced it there is. . . . I guess I knew that.
          • 1675
          Eric, curious as to what the book says? I noticed some free-play on mine, but I don't think it's as much as 10 degrees. Thanks!
          Whoops! Never mind, just saw your response with "minimal" being the key word. Thanks for passing that along.
          • indianut
            • Feb 2005
            • 308
            Eric, you can just weld the tang and regrind it. Also on the rotor, I just put a small piece of paper over the top of the shaft then push the rotor down onto it. It will tighten it up pretty well.
            http://laughingindian.com/
            A.M.C.A. Member Since 1986
              • 6019
              Harry, the exact wording is:
              Try to turn the rotor right and left. If it has too much play, the rotor shaft is worn. Free play on new equipement is approximately (1/8").
              Mine has quite a bit more than 1/8" so I'm looking for a new shaft.
              The book I have is "OPERATION AND MAINTENANCE, INDIAN MOTORCYCLE, MODELS 340-B/344"
              Very dry reading but it has been invaluable for my Chief and has more information than any service manual I've seen.
                • 6019
                Thanks Danny. I was hoping someone would say that as I have already silver soldered shim stock to the tang. The paper trick is brilliant.
                • fillibuster
                  red dog
                  • Aug 2009
                  • 934
                  "Tang" used to be something the astronauts drank. What are we talking about here? the bottom end of the shaft? The slot in the pump drive is pretty wide in my 47, and the blade (tang?) is pretty slim, which yields a lot of slop. I always set the timing while holding the rotor counter-clockwise against its driving direction, and rotating the distributor until the points sparked, and it always ran dam good there. But what always bothered me was the distributor's wobble that so many chiefs have. ... the zen-masters tell me to quit looking at it.
                    • Feb 2003
                    • 5353
                    Mmmm... a learnin' thread! Great stuff!!!
                    Oh, and it sounds like you want things perfect Phil!!! You must be some kind of antique motorcycle enthusiast or something....
                    Cory Othen
                    Membership#10953
