1940 Chief clutch
  • 1940 Chief clutch
    Hi guys,
    I just came across a problem assembling the clutch on a '40 Chief, the usual trick of using the primary cover didn't work because the clutch worm of a 40 model is shorter!
    Why was it changed on later models? I have ordered a tool from Jerry Greer.
    How much should the gap be between the assembled plates (new Greer assembly) and the basket?
    All answers gratefully received
    Thank you
    Regards
    Tim
    '36 four. '44 Chief & sidecar. '28 Scout. '67 XLCH. '70 BSA. and a Guzzi...............
    Hi Tim,
    I'm not sure why they changed over the years; different threads for faster action, etc.... But I like to keep the gap at .150", using a drill bit to measure this area between the pressure plate & spring plate.
    Is this the same Tim that drove the recovery Van for the Aussies?
    RF.
      Hi Fred, thanks for your help,
      Sorry I am not the recovery driver! prefer to be a rider
      Regards
      Tim
