1970 Brake Switch Wire
  • 1970 Brake Switch Wire
    I seem to recall that the wires that run from the brake switch to the coil and junction terminal were secured to the swing arm tube by a spring clip. If so, what is the Part Number of that clip? If not, how were these wires secured to the swing arm or frame?
    Thanks....
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    Ok - so nothing on the use of a clip. Given that, does anyone know if, after the wires leave the switch, do they wrap around the bottom of the swing arm or over the top? Also, while not shown in the parts book, were any wire tie-wraps used anywhere on the XLCH in 1970? I know they were commercially available then, but no reference seems to is made.
    Thanks..
    Bill Pedalino
    AMCA 6755
      IDK the answers to your questions, but have you tried sportsterpedia or the xlforum? They know a lot of these little details.
      AMCA #41287
      2020 Heritage Classic 114
      1989 Springer Softail project
      1972 FX Boattail Night Train
      1972 Sportster project
      1971 Sprint SS350 project
        You're right - I'll ask the question there.
        Bill Pedalino
        AMCA 6755
          The brake wires on my wife's 69 H go over the swing arm and then up. I don't know if this is correct, though... A zip tie is shown in the 71 parts book, but is listed as holding the front brake light wires to the handlebars.
          vph-d
            vph-d
            Thank you for responding. Someone on the XL forum also stated that they go above the swing arm. But above or below, I just don't see how they can make the two 90 two degree turns and stay in place without a tie wrap.
            Bill Pedalino
            AMCA 6755
              The wife's brake switch wires are zip tied to the swing arm and to the down tubes, again I don't know if this is correct.
              vph-d
                I spoke to very knowledgeable Sportster guy yesterday and he stated at that time, the wires were taped to the swingarm.
                vph-d
                  vph-d
                  Ah Ha! - That makes sense, as friction tape was used by the factory on my '47 (and other earlier bikes) to hold the loom to the secondary support under the gas tank. Thank you to sharing that information!
                  Bill Pedalino
                  AMCA 6755
