spiral speedo gear missing
  • Guest
    why is the spiral gear on counter shaft first missing on my 63 xlch. There does not even seem to be room for it on the shaft. The drive unit has been cut, the hole welded shut and then threaded back into the case. Is it normal to alter the case or bearing area when this is done? As I said I don't see room for the spiral gear between 1st gear and the case. I'm trying to get a speedo working on this bike and this has me cornfused. thanks
    Somebody made sure they weren't going to blow the rear of the case out. Does the case look like it has been repaired in the left rear corner? Bob L
    • Guest
      Yes it does. There is a weld on the left case from the primary to the center line. What happened?
      • jim d
        • Sep 2010
        • 280
        That was a weak area in the case and they were known to break there when the riders were doing burnouts and flat shifting them. There was a counter bore in the case for the speedometer drive and when repaired you lost that. I have seen the whole corner of the case busted out.
        Jim D
        • Guest
          So the stock speedo set up is not an option without major case work I take it. What are people doing for a speedometer?
          • Guest
            thanks for the replies by the way
            • motorhead1
              • Dec 2006
              • 171
              If you want to keep the front drum brake you can get creative and retrofit a front wheel speedo drive assembly. There are also rear wheel drive setups out there. I had to do it with my '72 XLCH.
              Ride 'em. Don't hide 'em.
              Dan #6938 FUBO
              • Guest
                Cool! What did you do for the front wheel set up? That would be awesome.
                • larry
                  • May 2009
                  • 247
                  I did that repair/upgrade to later shaft on a '53 K. The original design was so weak that even a K model would break it.
                  • Guest
                    Do you mean you beefed up the case around the counter shaft bearing?
                    • larry
                      • May 2009
                      • 247
                      Yes, and the later shaft uses a smaller Torrington, leaving more metal on the case.
                      • Guest
                        Oh I see. Now things are starting to make sense. But still, what to do about a speedometer? Why do things have to be so difficult?
