Motor Mount Bolts
  • billpedalino
    • Mar 2005
    • 1096
    Motor Mount Bolts
    I have recently been informed that my 1964 XLCH had the older parkerized front lower motor mount bolts (thanks Murph!). However, in addtiion, I now believe that there were actually two earlier types of the parkerized bolts and two types of later cadmium-plated bolts. The earliest consisted of 3/8" rods with with both ends threaded and a nut welded onto one end (I just fabricated one of these sets). The next type consisted of 3/8" threaded rods with the nuts threaded-on and stamped in place soas not to turn (I have one of these OEM sets). The next type of bolts were stamped and cad-plated. The latest (final) series of bolts were actual bolts with formed heads.
    The two questions that I have are as follows: Is the above accurate? What year did the bolt and spacer finish switch from Parkerized to cadmium? I know for sure that 1964 were parkerized and that 1968 were cad, but I don't remember which year was the change-over.
    Thank You...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • Robert Luland
    • Sep 2007
    • 2075
    Bill the second type Was not stamped. It was just a heavy lock nut. The mark on them is how they make them. I also had to reproduce them for my 65 XLCH.
    Bob L
    AMCA #3149
    • Sportster Jerry
      • Jul 2007
      • 165
      1967 was still parkerized.
      • billpedalino
        • Mar 2005
        • 1096
        Thank you gentlemen... Looks like 1968 was the changeover year...
        Bill Pedalino
        AMCA 6755
        • Sportster Jerry
          • Jul 2007
          • 165
          Bill, I was a little groggy when I answered this last night. I believe 1966 was the first year for cad bolts, not 1968. They might have even changed during the 1965 model year.
          • billpedalino
            • Mar 2005
            • 1096
            Thanks Jerry - duly noted!
            Bill Pedalino
            AMCA 6755
