confused
  • ironhead john
    • Aug 2013
    • 6
    confused
    my engine oil is draining into clutch what the hell is going on I thought they were two different systems please help a uninformed biker out
    • 1667
    John, don't know the ironhead at all, but it sounds like a bad seal between crankcase and primary.
    • vph-d
      • 1082
      Older Sportsters , 76 and back, had a transfer valve located in the left crankcase wall behind the primary chain. Perhaps this valve has failed.
      VPH-D
      • kg993
        • 263
        The transfer valve VPH-D mentioned is the usual problem. I've tried flushing them out but never had any luck getting them to seal. They are a bear to get out so if it's not the main seal leaking I just epoxy over the valve.
        Kerry AMCA # 15911
