'69FLH rear wheel cyl.
  • '69FLH rear wheel cyl.
    Good morning
    Threads are gone where banjo bolt goes.Has anyone used RE-COIL or the like to fix?
    Don
    That boss is pretty thick. I don't see why you couldn't put a thread insert in it.
      I had one like that. It was neccesary to replce it, becuse it fits the banjo bolt, so it is a weak area.
      Mike
        I stand down on this one. I was thinking of my 60s which is the straight one and mics at .7425 OD which is a lot of meat. I don't have the later on to look at. Sorry about that. Bob L
        I just went on line to Lucifer's kitchen and looked at that wheel cylinder. There sure looks like there more than enough meat to pull it off. Bob L
          Thank you both for the replys.
          Thinking I might try the fix,don't have much to lose if'n it don't work.
          Don
