70 FLH Front Brake Switch?
  • r.mac
    student
    • Dec 2007
    • 25
    Hi all, My 70 E-Glide has a (broken)front brake switch in the perch, think it was added after? i got the bike all pimped out parade style, lots o'lights
    thanks
    • 5946
    The '70's did have a very small brake light switch on the hand brake lever bracket.
    • rashd
      • Feb 2006
      • 77
      ...in the housing, next to the brake cylinder reservoir. It's not too bad to deal with unless the wiring has been run through the bar. Finding a decent switch can be a chore, though.
      # 5844
        • 5946
        RASHD,
        A 1970 doesn't have disc brakes. It is a mechanical drum brake.
        • bmh
          • Feb 2007
          • 901
          the correct switch is tough to find also. The switch from a 74 disc brake perch can be modified to work by cutting off most of the long plastic tail, but it is visually different.
          Brian Howard AMCA#5866
          • rashd
            • Feb 2006
            • 77
            haynes
            sometimes I get a narrow view and shoot from the hip...
            that little switch hits a nerve every time...I don't know how the early switch looks...
            # 5844
              • 5946
              It looks like number 13 in this list.
              • Neil74
                • Aug 2008
                • 98
                That would be number 12 Chris, drum brakes in 70
                  • 4770
                  PM me, I have a new one.
                  Robbie
                  • flat-happy
                    • May 2009
                    • 543
                    not easy to catch chris---
                    • r.mac
                      student
                      • Dec 2007
                      • 25
                      thanks chris, my parts manual doesn't even list that part! appreciate all the help
                      sent you a pm Rub, thanks all
                      • r.mac
                        student
                        • Dec 2007
                        • 25
                        thanks Brian, i ended up with one of those, cutting the plastic divider and heat shrink tube; it works...
