correct finish??
  • D.A.Bagin
    • Jan 2008
    • 595
    correct finish??
    Could someone tell me what the correct finish is for the nut that holds the battery support to the rear frame downtube is on a 68 flh?? Is it painted black, cad, or something else? What is the finish on the stud also? Thanks in advance.
  • camsaure
    • Nov 2009
    • 135
    I'll check
    In a few weeks I will see a person who has an unmolested 68. I will try to remember to check this out for you. The only thing touched or changed on this bike was the starter was rebuilt and repainted a couple of years ago. Cam
      • 5946
      It is Parkerized. The stud is part of a rubber isolator. They were usually zinc plated.
      • D.A.Bagin
        • Jan 2008
        • 595
        Thank you very much Chris.
