76 FLH Front Banana Caliper problem
    • 4775
    If your mechanic replaced the piston when he did the brakes you need to know if it was a correct front type or a rear type. They do not retract the same amount!
    • vph-d
      • 1082
      I agree with Robbie. The front and rear pistons are a different part number. I'm guessing the new piston is the problem.
      vph-d
      • RodFun
        • Jul 2018
        • 18
        Thanks everyone for your advice. My mechanic re-built the master cylinder and put in a new brake line and the calipers were still not retracting well, so we decided to just go with a new caliper. Expensive, but its fixed.
