76 FLH Front Banana Caliper problem
  • RodFun
    • Jul 2018
    • 18
    I'm a newbie '76 Shovelhead owner and finding my way bit by bolt. I had to remove the front caliper to replace the bushing, which was causing the caliper to rattle like a trash can, and that fixed the problem. I thought I had reassembled the caliper correctly, though I may have had an extra washer left over. It seemed fine though on the few short rides I took before winter set in. This spring after a couple rides which seemed OK, I thought I smelled brake shoes from the car in front of me, and then noticed the brake lever got hard. And when I rolled the shovelhead into the bike barn it was hard to push. So it wasn't the car in front of me. It seems the front brake was grabbing and wouldn't let go. Returning to the bike after it cooled down, the lever was easy again and the bike rolled fine. This happened again on the next ride. So I am going to disassemble the caliper again and just thought I'd put it out there to see if anyone could share thoughts theories so I know what I'm looking for. Thanks.
  • dukekleman
    • Jul 2022
    • 594
    Rodfun,
    A) What you are experiencing is typically caused by the fluid level in the master cylinder on the handle bars being to "Full".
    Please verify the fluid level is not overfilled. It requires a proper air gap above the fluid to allow it to expand when the fluid warms up from braking friction.
    B) Your master cylinder piston may not be fully returning to its home seated position determined by the return spring and snap ring. If the case, the fluid can not retract properly when the hand brake lever is released, causing drag.
    C) There is a pressure bypass and an equalization port in the master cylinder. They will become restricted and plugged due to lack of Brake fluid service work. If they are not open, your brake will hang up.
    D) The piston in the brake caliper maybe be hanging up and not "retracting" as designed when the hand lever is released. This can be caused by a piston that needs cleaning, caliper seal grooves that need proper cleaning or aftermarket caliper seal kits that measure dimensionally larger than OEM.
    Hope this helps,
    Duke Kleman
    • marksg
      • Mar 2023
      • 128
      Exactly what Duke said.
      Short version, check the vent hole in the master cylinder cap.
      I goofed one time and painted mine shut and had the same issue.
      • otis71
        • Jul 2015
        • 593
        If it started immediately after working on the caliper, I would suspect the caliper first or overfilled cylinder like Duke suggested.
        • RodFun
          • Jul 2018
          • 18
          I just checked and the master cylinder well is about a quarter inch from the top and the vent seemed clear when easily I ran a wire through it. I believe it was working fine before that, but I hadn't ridden it much at all as winter came on fast here. When I disassembled the caliper I did not disconnect the brake line or open the master cylinder or bleed it. Didn't seem necessary. After I replaced the bushing I just re-assembled it. So I assumed I did something wrong on re-assembly.
          It was gone through and set up by my experienced mechanic, and I quote: "Front brake caliper and master cylinder leaking and generally in poor condition. Rebuilt caliper, replaced puck. Installed new pads. Cleaned out M/C, dressed surface installed new gasket." I'm going to take it back to him for some other work but he's 200 miles away and I was hoping to ride it up there. So maybe I need to just disassemble and see if anything jumps out at me.
          Thanks everyone,
          Rod
          • dukekleman
            • Jul 2022
            • 594
            Rod,
            If you elevate the front tire, does it spin freely before you ride it?
            Or
            Does it have a drag ...light drag or heavy drag?
            I have a few other suggestions based on your findings.
            Duke Kleman
            • RodFun
              • Jul 2018
              • 18
              It has a fairly heavy drag. Spins less than 1/4 turn.
              • dukekleman
                • Jul 2022
                • 594
                A couple of things to check for:
                A) The thickness of after market brakes can be an issue if they are thicker than OEM, which isn't uncommon.
                B) The replaced puck you mentioned could be out of dimension and not allow enough space when fully retracted.
                C) The new bushing you installed may not have enough clearance to were it doesn't " Float " on the pin causing drag.
                D) The new bushing may not be pressed into the bore parallel causing a issue with parallelism and float.
                While I don't believe this is an issue in your situation, it should be noted that the correct wheel bearing endplay is important for the operation of the brake as well.
                Hope this helps,
                Duke Kleman
                • RodFun
                  • Jul 2018
                  • 18
                  Thanks so much, Duke. Will tackle it today and let you know what I find.
                  • joe fxs fxr
                    • Dec 2020
                    • 694
                    Before you take anything apart, try to slide a thin feeler gage between the pads and rotor and note if one or both are dragging.
                    AMCA #41287
                    1971 Sprint SS350 project
                    1972 FX Boattail Night Train
                    1972 Sportster project
                    1973 HD Golf Cart project
                    1989 Springer Softail project
                    2020 Heritage Classic 114
                    • RodFun
                      • Jul 2018
                      • 18
                      Joe, I had to loosen the bolts to get the .006 feller in. I tightened back to 30lbs and the back feeler is pinned, the front feeler I can pull out with some resistance.
                      • dukekleman
                        • Jul 2022
                        • 594
                        Rod,
                        Without pictures of your actual project, one can only make assumptions and this is my thought...
                        If your new brake pads thickness fall into specification and there is no binding in the float per previous conversation, it sounds like you may have an alignment issue.
                        This could be due to axle spacers or brake disc spacing.
                        Do you have part number 41814-76 in place on your motorcycle? This moves the alignment outboard and would alleviate the force on you inside brake pad. The caliper piston would compensate for this shift in alignment. See images below I took for you.
                        Number 21 in the photo above and shown install in the photo below.
                        I hope this helps,
                        Duke Kleman
                        • RodFun
                          • Jul 2018
                          • 18
                          Thanks Duke for your support. I have a call in to the mechanic who rebuilt the brake, so hope to get some insight from him.I do have the spacer in.
                          • joe fxs fxr
                            • Dec 2020
                            • 694
                            That tells me the piston is retracting but the either caliper isn't sliding or the pads are too thick. Check the motion of the caliper on the pins.
                            AMCA #41287
                            • PRG
                              • Nov 2006
                              • 612
                              Howdy sir,
                              As Duke mentions, aftermarket pads can confuse diagnosing brake issues. When fitting mine on my 77 there was what seemed to be minimal drag in the running state which “preheated” the pads, if you will, such that a few brake applications sent the brake fluid temps soaring and onset of binding. Thankfully, had a 7mm wrench on hand, bled off some fluid and motored home without further application. Assumed this might be an issue with the puck not retracting properly in the caliper and thus “exercised” by repeatedly compressing the piston back and forth into the body. Reassembled and repeat of before. This time, compressed the piston to the base of the bore, reassembled and discovered I still had drag. Removed the aftermarket pads, decked to them to .265, problem solved.
                              Cheerio,
                              Peter
                              #6510
