My 1973 electraglide was ideling just adfter start up i noticed that oil a cup or so had came out of the vent hose onto the floor then i noticed that the oil light had stayed on . I shut it off any ideas . I just filled the oil tank a few days ago could have I overfilled the tank and caused this problem
1973 oil sensor
When the tank has emptied into the crank from sitting, Idfly,...Originally posted by ldfly112 View PostMy 1973 electraglide was ideling just adfter start up i noticed that oil a cup or so had came out of the vent hose onto the floor then i noticed that the oil light had stayed on . I shut it off any ideas . I just filled the oil tank a few days ago could have I overfilled the tank and caused this problem
Topping it off certainly is more than 'design', but pukeing out the breather is better than blowing out cylinder base gaskets and such.
The sending unit shouldn't be affected, unless you somehow achieved a diabolical air-lock. Please remove the sending unit to allow air to purge before another trial.
With luck, the gremlin jumps out.
....CottenAMCA #776
- 1 like
Gosh, Idfly,..Originally posted by ldfly112 View PostAnybody know where I can purchase a american made oil sending unit . tired of wasting money on repop junk Thanks if you can help
You mean you think you've got a repop that died?
You could always test it:
https://forum.antiquemotorcycle.org/...pressure-gauge
Lest you throw money at it,
...CottenLast edited by T. Cotten; 02-12-2024, 05:46 PM.AMCA #776
- 1 like
You'll have to disassemble the right side of the engine to determine why the pump stopped operating.
It is Likely a woodruff key for a gear has failed, but WHY???
Locate the actual failure and then locate the cause(s) of that failure. Let us know what is found and possibly good photos. This will help all of us in determining a possible cause of that failure.
This way it can all be fixed at one time while it's apart.
Duke
If the pump is properly 'primed', Idfly,.Originally posted by ldfly112 View Postafter looking into the pressure switch it checked out fine. No oil returning to the tank. any ideas what to check next is the oil pump rebuildable or should I replace the pump any ideas Thanks
(Meaning oil purges freely when the sending unit is removed: no 'air-lock'...), then a drive key possibly sheared.
Only opening the pump, and possibly the cam cover, will tell.
A half-century or so ago, I a tiny chromed screw with wire still wrapped upon it came out of my new Paughco oil tank; Sheared the key on a feed gear, but no other damage, thanks to the idiot light!
PS: The most difficult aspect of the chore is getting the assembly to seal, as oil will continue to foul gasket surfaces as it drains from the rest of the motor, forever.Last edited by T. Cotten; 02-22-2024, 11:40 AM.AMCA #776
- 1 like
I could not find anything wrong with the lifters rollers all looked good no missing needle bearings. the existing key ways were very hard to remove took a lot of time to get them out of the slot the oilpump drive gear in the cam chest was a bit worn so I replaced it put it back together last night started up and the oil light went as it was supposed to ill take it for a test ride today but i agree with dukekleman I wish i could have a reason for the problem Ill let you know how the test ride goes THANKS for all the help
Possible debris from primary chaincase returned to engine?There is an aftermarket inline screen available for primary return oil.
Sidenote:The camcover has to have both areas sealed from each other or they can start sending the oil out the crankcase breather as you go down the road. Common problem with aftermarket chrome cam covers.
