1973 oil sensor
  • ldfly112
    • Sep 2017
    • 146
    1973 oil sensor
    My 1973 electraglide was ideling just adfter start up i noticed that oil a cup or so had came out of the vent hose onto the floor then i noticed that the oil light had stayed on . I shut it off any ideas . I just filled the oil tank a few days ago could have I overfilled the tank and caused this problem
  • tgarcia
    • Jan 2023
    • 116
    Look in your oil tank and make sure you are seeing oil return
      • 8233
      When the tank has emptied into the crank from sitting, Idfly,...
      Topping it off certainly is more than 'design', but pukeing out the breather is better than blowing out cylinder base gaskets and such.
      The sending unit shouldn't be affected, unless you somehow achieved a diabolical air-lock. Please remove the sending unit to allow air to purge before another trial.
      With luck, the gremlin jumps out.
      • ldfly112
        • Sep 2017
        • 146
        Anybody know where I can purchase a american made oil sending unit . tired of wasting money on repop junk Thanks if you can help
          • 8233
          Gosh, Idfly,..
          You mean you think you've got a repop that died?
          You could always test it:
          https://forum.antiquemotorcycle.org/...pressure-gauge
          Lest you throw money at it,
          • BigLakeBob
            • 2766
            Napa has some that will fit, probably made by our southern neighbors, but better quality than those made south of Mongolia.
            Bob Rice #6738
            • vph-d
              • 1088
              I have used the EVO style sending switch on earlier motors with good results.
              vph-d
              • ldfly112
                • Sep 2017
                • 146
                after looking into the pressure switch it checked out fine. No oil returning to the tank. any ideas what to check next is the oil pump rebuildable or should I replace the pump any ideas Thanks
                • dukekleman
                  • Jul 2022
                  • 595
                  You'll have to disassemble the right side of the engine to determine why the pump stopped operating.
                  It is Likely a woodruff key for a gear has failed, but WHY???
                  Locate the actual failure and then locate the cause(s) of that failure. Let us know what is found and possibly good photos. This will help all of us in determining a possible cause of that failure.
                  This way it can all be fixed at one time while it's apart.
                  Duke
                    • 8233
                    If the pump is properly 'primed', Idfly,.
                    (Meaning oil purges freely when the sending unit is removed: no 'air-lock'...), then a drive key possibly sheared.
                    Only opening the pump, and possibly the cam cover, will tell.
                    A half-century or so ago, I a tiny chromed screw with wire still wrapped upon it came out of my new Paughco oil tank; Sheared the key on a feed gear, but no other damage, thanks to the idiot light!
                    PS: The most difficult aspect of the chore is getting the assembly to seal, as oil will continue to foul gasket surfaces as it drains from the rest of the motor, forever.
                    • ldfly112
                      • Sep 2017
                      • 146
                      After removing the cam cover and checking the gears i found a keyway sheared it appeared that one gear the one on the end of the oil pump shaft slightly damaged and the shaft was damaged ordering parts today Thanks for all the help
                      • dukekleman
                        • Jul 2022
                        • 595
                        IDFLY,
                        Did you determine what caused the woodruff key and gear failure?
                        Something would have passed through the gear causing the stress that sheared the woodruff key.
                        As I mentioned earlier in the post above, possibly a tappet roller needle?
                        Duke
                        • ldfly112
                          • Sep 2017
                          • 146
                          I could not find anything wrong with the lifters rollers all looked good no missing needle bearings. the existing key ways were very hard to remove took a lot of time to get them out of the slot the oilpump drive gear in the cam chest was a bit worn so I replaced it put it back together last night started up and the oil light went as it was supposed to ill take it for a test ride today but i agree with dukekleman I wish i could have a reason for the problem Ill let you know how the test ride goes THANKS for all the help
                            • 2030
                            Possible debris from primary chaincase returned to engine?There is an aftermarket inline screen available for primary return oil.
                            Sidenote:The camcover has to have both areas sealed from each other or they can start sending the oil out the crankcase breather as you go down the road. Common problem with aftermarket chrome cam covers.
                            • ldfly112
                              • Sep 2017
                              • 146
                              The inline screen sounds like a great idea where can I purchase the aftermarket screen
