Push rod tool
  • 1970 XLCH
    • Nov 2010
    • 177
    Push rod tool
    Is there an official tool for removing pushrods that are too long ? My 1971 FLH has hydraulic tappets ( S&S ) & colony push rods . Problem is that the intake push rods cannot be removed when the hydraulic units are pumped up . It is just a matter of about 1/16 of an inch or so . I have used a couple of small wrenches , that worked , but I really don't like this method . The reason this is happening is the valve seat is at it's limit , so the valve stem is sticking out farther thus putting the rocker arm cup down further . So I have to make the pushrod open the valve slightly to remove the pushrod . Any help would be appreciated . Thanks, Mike
    • 4784
    Yes, there is. This is what it looks like:
    • pan620
      • Oct 2016
      • 223
      Rubone, is that a factory tool? Never seen or heard of one. Thanks dave
      • 1970 XLCH
        • Nov 2010
        • 177
        Thanks Rubone ! Is there a part # ?
        • 1970 XLCH
          • Nov 2010
          • 177
          Found it , Colony 3056-1 or Teds 3056-1T
            • 8233
            Never heard of such a thing!
            PS: Bottom tool was for covers.
            Lyman bullet ingot used for a soft fulcrum;
            Motor sprocket toothmarks indicate another application.
            • jim d
              • Sep 2010
              • 281
              I also have one for the XL models. They both look like Robbie's just a different size on the end. We made ours in the 70s.
              Jim D
                • 4784
                It is a factory tool, part # is 96930-52 Push Rod removing tool. Used them a lot in the '70s with crappy hydraulics and oiling issues.
