Jims Powerglide tappets
  • 1970 XLCH
    • Nov 2010
    • 172
    Has anyone had any experience with JIMS powerglide tappets (# 2461-1) ? I have read some bad ( and good )reviews online . I've just installed them on my '71 FLH but haven't fired it yet . Any feedback would be appreciated . Thanks , Mike
  • tomanybikes
    • Dec 2005
    • 19
    I've used them. Had a couple that would randomly bleed down overnight and cause hard starting, missing on one cylinder until the engine had run long enough to fill it with oil. The original set I had were the "big axle" version. Two of those wore out the roller pin in less than 10K miles. I replaced the first one with the standard axle version and when the second one wore out, I changed out the whole set and went with solids. There was a noticeable difference in starting and throttle response after changing to the solids. I'm saving my pennies to get a set of Velva Touch because I'm sure I'll eventually get tired of listening to the solids clattering away.
    • BigLakeBob
      • 2757
      Easier starting or harder starting, less throttle response or more throttle response? Thanks.
      Bob Rice #6738
      • pan620
        • Oct 2016
        • 223
        The stuff i have got in the last few years from Jims was a disappointment, and way over priced.
        • kitabel
          • Sep 2018
          • 471
          JIM's response to any & all complaints of poor quality: "We don't make mistakes".
          The Linkert Book
          • tomanybikes
            • Dec 2005
            • 19
            Easier starting with the solids particularly when cold, I believe because the Jim's units leak down and don't open the valve (much) until it fills with oil again. I notice better throttle response with the solids particularly at lower RPMs. I'm using an Andrews #2 cam.
            • 41craig
              • Nov 2010
              • 409
              I bought a set of Knucklehead rocker arm shafts from Jim's for 74" motor in 1993. They were good quality, but had machine shavings in oil passages. Not just a bolt on item !!
              Craig
              • pan620
                • Oct 2016
                • 223
                Bought some case races for a 1947EL, needed .020 "lapped" out of the before being installed.
                • 1970 XLCH
                  • Nov 2010
                  • 172
                  These tappets didn't work for me. Bad conversation with "Eagle " on the phone . Wrote them a letter , with no response . Will never buy Jims products again !!
                  • kitabel
                    • Sep 2018
                    • 471
                    4-speed transmission case race is another example: way too small to fit, way too hard to lap.
                    The Linkert Book
