67 Shovelhead 4 Speed
  • sieber60
    • Jul 2014
    • 81
    Does anyone know if there is a tool made to install a main drive gear shaft seal for 67 4 speed, as you know this is a small seal and difficult to get started straight. ? Or any advise on installing one. As always I appreciate the info.
    With the exception of turning down a piece of round stock and making your own. I know of non. Just put a socket on it and have way with it. Bob L
    • TomL
      • Jan 2018
      • 109
      I always bought a couple extras when replacing that seal!
        • 4784
        PVC tubing.
          • 2030
          I make seal installers on my lathe out of PVC like Robbie said.I take dimensions & go to hardware store & buy a pipe or usually connector & turn it down.The seal is supposed to be .050" in from face of case,so I make a step to set to right depth
          • Phat
            • Jun 2019
            • 13
            DF244591-AB48-4F3E-9E03-2D4AC3B3617A.jpgi use and ild 5 c collet
            • aumick10
              • Nov 2018
              • 465
              Jims make a tool, #2256-1, but at around $100, you would need to use it almost daily to make it worthwhile.
