1967 Compensator Nut
  • sieber60
    • Jul 2014
    • 81
    Is the compensator nut left or right thread on a 67' FLH? Manual doesn't say. Appreciate the info. as always!
    • 4784
    Right hand.
    • Phat
      • Jun 2019
      • 13
      Only left nuts are trans......
      • sieber60
        • Jul 2014
        • 81
        Okay.. I currently have a 23 tooth compensator sprocket and a 22 tooth transmission sprocket and a stock rear drum brake sprocket .. 51 I think. What would change if I used a 22 tooth compensator sprocket?
          • 4784
          Your acceleration would be quicker, your top speed would be lower. 22 was commonly used for sidecar service, 23 was standard for FL, 24 was for high speed use and FLH.
