1971 FLH Fork lower legs
  • 1970 XLCH
    • Nov 2010
    • 177
    Haven't been able to find the tolerances on the lower leg bushings . Also if they are out , does anyone have a resource on who replaces bushings ? Thank you , Mike
  • TomL
    • Jan 2018
    • 109
    Mike, the way it reads in the Service Manual the reamer tool that is used to size new replaced bushings is made to give the correct tolerance after it is used on the new bushings. No dimensions given, one pass through and done.
    V-Twin sells the bushings. They also offer complete remove/replace/sizing. Your decision on that part of the matter.
      • 4770
      Bill's in PA was offering the service, check with them.
      Custom Cycle shop that specializes in vintage Harleys. Large selection of parts and an extensive workshop for repair and restoration work. | Bill's Custom Cycles
      • ammorest
        • Sep 2008
        • 293
        A friend has a pair done for a '51 FL by Bill's. Good work, decent turn around time.
