advance weights and timer cam
  • Guest
    Can some one tell me the correct way for the small timing cam to go into the advance weight mechanism? It will go in correct and also 180 degrees different. How do I know which is correct?
  • vph-d
    • 1088
    Isn't there a difference in the depth of the slots on the cam?
    VPH-D
      • 8233
      Dustydog!
      You can't know until you bring up the timing mark on the front cylinder's compression stroke.
      Then it goes in (or the whole timer into the cases) with the small lobe pointing toward the cam follower.
      On my '65s, anyway..
      • Guest
        That is just exactly what I did. Thanks Cotton, I am grateful for the answers. VPH-d, no the cam can go in either way. One side has a flat on it but I don't know why. But like Cotton says , front cylinder on compression has to line up with the narrow lobe.
          • 4784
          On timers with a flat on one side of the cam there is a small roll pin in the base to locate it.
          • Guest
            Does the roll pin keep the cam from being installed backwards?
              • 4784
              Yes, that is the intention.
                • 8233
                I think that's a 'cone' motor thing, Dustydog,...
                This '66 or so timer has none, and the sides of the cam are symmetrical.
                • Guest
                  thanks everyone!
