drum brakes on right side through the 1968 model year (year that I have), right side thereafter thru the 1972 model year.
difference between 1966 and 1969 heads?
dumb error on my part, front drum on left 49 - 68. Right side thereafter. (Kinda hard to switch the drum brake from the right side to the right side, ain't it).Lonnie Campbell #9908
South Cackalackey, U.S. of A.
My favorite Shovelhead picture........Attached FilesLouie
YouTube >>> LouieMCman
WHAT Shovelhead?Originally posted by LouieMCman View PostMy favorite Shovelhead picture........
The short reach plug shovelheads with the '66 cast in the vertical surface by the spark plug hole also have a date code cast into them. Pretty hard to see when the rocker boxes are in place, the code is a month and 2 digit for the year, cast into the top of the head, right next to the short rocker box stud and behind the push rod tubes. It will be something like 5 68 for May of 1968 as an example. You might be able to make it out if you poke a flashlight into the area under the rocker box and behind the push rod tubes. These date codes were used untill about '78, I believe.
