1948 Panhead Headlight?
  • MMasa
    • 1192
    I'm currently restoring a very low number 1948 Panhead. I was told recently by someone who has been involved in antique motorcycles for quite a while (40-50 years) and whose opinion I have learned to trust that 1948 big twins had a one year only headlight with a sealed beam. I've never heard of this but when I check my parts book, the bulb, wire / plug, and bezel rings, etc all have dash 48 part numbers. The exception is the bucket which has a dash 49 part number but it is also mounted differently on a 1949 up hydraglide fork. Was there a 1948 only headlamp with a sealed beam used on big twins? It seems for certain that the cycle ray was still used beyond 1947 on 45 solos, servicars, etc.
    This guy had a couple of these on his shelf with his EXTENSIVE inventory.
    I looked in my stuff and found one too. It has the Bakelite electrical connection block like on a standard cycle ray as well as the spherical divot where it mounts to the fork headlamp bracket but it has a sealed beam. The back of the bucket is more rounded and is not marked Cycle-Ray.
    Anyone have any ideas?
    I'll try to post some pics of what I have.
    Mark Masa
    Mark Masa
    www.linkcycles.com
  • 46EL
    • Apr 2009
    • 728
    I have never seen a 49 style Lamp that has the-48 part number in a cycleray bucket yet alone on a 48 pan.
      • 4791
      All the numbers in the '48 parts book still list the -35 numbers. The '49 parts book lists a -48 headlight assembly as black for '49 model year. All the other -48 part numbers are also listed as '49. You may have Beck sealed Beam unit that was offered as a replacement for '48 and earlier H-D. I have never seen a sealed beam unit on any original '48 and a sealed beam will not fit into a -35 part number shell, the diameter is too small. Are there any markings or numbers anywhere on it?
      Robbie
        • 6044
        I've had this light kicking around for years. I assumed it was for an Indian.
          • 6044
          Another view.
          • 46EL
            • Apr 2009
            • 728
            Probably 48 and up Chief.
            • MMasa
              • 1192
              Eric
              The light that you have posted pics of is just like the one that I have and also like the two that this guy I was talking about had on his shelf. Maybe his memory is foggy? Like I'd said before, a 48 only Panhead headlight was something I'd NEVER EVER heard of so I figured I'd ask. I guess I'm still on a hunt for a good usable cycle-ray.
              Is it in fact for an Indian? What year(s) FOR SURE?
              Thanks for the help.
              Mark
              Mark Masa
              www.linkcycles.com
                • 6044
                Mark, as 46EL stated; it's probably '48 and up Indian. I too have a '48 FL and I've looked at a lot of them over the years and I have never seen anything but a Cycle-Ray fitted. I have a question myself, regarding the Cycle-Ray. I have seen large script and small script on the back of those lights. Does that define the years they were used ?
                • MMasa
                  • 1192
                  The only marks on the lamp that I have is on the bottom of the bezel. It reads "Pat. No. 2458007" I looked it up and it's a patent for a "Securing band or ring" granted to the DIETZ CO R E on Jan. 4th 1949.
                  Mark
                  Mark Masa
                  www.linkcycles.com
                  • 46EL
                    • Apr 2009
                    • 728
                    IN the last 2 or 3 years I saw 2 very original Knuckles and a 48 Pan here in New England that were barn fresh bikes and they all were updated with sealed beam Indian Chief Headlights. I'm thinking it was probably an update that helped you see beter at night? The 46FL that was at Rhinebeck last year that originally surfaced here in Connecticut had one also. 46el
                    • Matt McManus
                      • Dec 2007
                      • 142
                      I have a mid year production 48 EL in its original condition. It has a cycleray.
                        All springer models up the 1957 Servi-car used Cycle Ray headlamp. H-D never had a sealed beam on a springer.
                          • 6044
                          I'm still curious about the Cycle-Ray logo on the back of their headlights. I have seen a large logo and a small logo. Does the logo size correlate to specific years ?
                            There are several variations of the Cycle Ray. The pre war units do not have a ground wire attached to the inside of the bucket. During WWII a hole was drilled in the bucket and a screw,nut, and washer held this wire in place. Sometime much later the wire was riveted to the bucket. I don't know when the rivet arrived. There are at least two variations on the GUIDE and Cycle Ray on the back of the bucket. I don't know when those changes were made.
                              • 6044
                              Thanks Chris; my bucket has the rivet and small logo, which is on the 48FL.
