heads for the pan
  • esquire
    • Sep 2010
    • 49
    heads for the pan
    I just looked in the how to restore book and seen that there is a casting # on the head between the push rods . after looking at my 62 pan there are no casting # on them so that means I have a aftermarket set of heads is this true ????
  • Lloyd
    Lloyd
    • Aug 2005
    • 106
    Esquire, By casting numbers do you mean part #? The part # on my 61 heads are under the pan cover between the pushrod holes. Can not see the # when together....... Lloyd
    • esquire
      • Sep 2010
      • 49
      cool I will take one of the covers off and see Thank you Esquire
      • esquire
        • Sep 2010
        • 49
        I took the covers off and found the # Thank You so much
        Esquire
        • upsrod
          • Feb 2010
          • 320
          There should be a date code too.....Rod
          • esquire
            • Sep 2010
            • 49
            it has 61 on there would that be right for the 62 pan??
            • upsrod
              • Feb 2010
              • 320
              Yes, depends on when it was built. My 62FL6562 was built on 12-6-61 and both heads are dated September of 61.....Rod
              • Perry Blake
                • Jan 2008
                • 9
                The heads on my '57 are dated '55 but they have 12 rocker cover mounting screws in stead of 6.
                Is it posible that some heads came from the factory dated '55 with 12 mounting screws or is it more likely that someone drilled and tapped them later?
                Thanks in advance, Perry
                PMB
                • 58Panheadfan
                  • Dec 2006
                  • 33
                  Hi upsrod... where did you get your infos about production date from your 62FL!?
                  Harry
                  • cdndewey
                    • Jan 2005
                    • 438
                    Harry
                    I was wongering the same thing myself. I'm curious about my 62FL2897.
                    • upsrod
                      • Feb 2010
                      • 320
                      Harry and Dewey, You can get the information from Harley-Davidson. Harry, they have no information on 58's, I have tried every angle. Dewey, if you have the belly numbers and the anti-theft numbers on the frame,trans and fork they can verify all of that and tell you the build date. Peter J. Simet (414) 343-4056 ......Rod
                      • esquire
                        • Sep 2010
                        • 49
                        I think you get the date and the month of the frame , right by the top ,back, gas tank mount look in the HOW TO RESTORE YOUR HARLE-DAVISON book
                        • esquire
                          • Sep 2010
                          • 49
                          I don't know how I got here I was on Pan heads
                          • esquire
                            • Sep 2010
                            • 49
                            I think you can find the month and year on the frame , on top and the back gas tank mount
                            Look at your HOW TO RESTORE YOU HARLEY-DAVIDSON BOOK
                            Esquire
                            • indianut
                              • Feb 2005
                              • 308
                              I believe what they tell you is the Date it LEFT the Factory.
                              http://laughingindian.com/
                              A.M.C.A. Member Since 1986
